Ex.- a person walking through a room with a light on the wall like in a parking garage with pale grey block walls . Vertical lines on wall, with oval lines around light, lines blocked by darker colors like the man, as he walks the lines change shapes, ie. from vertical to oval around the light and squiggly to vertical, etc as the picture changes.Darker colors hide the lighter lines
SOURCE: Vertical line
Sorry, you have a defective LCD panel. If your TV is still under warranty, contact Sharp to get the TV exchanged. Otherwise, LCD panels cost more than the TV is worth.
SOURCE: dark transperant vertical line, left side of screen
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
SOURCE: light grey vertical line
I believe there are 3 possible causes for this issue; toner drum, fuser or transfer roller - more than likely I would dismantle the printer and check for lines on the fuser. But just in case remove the toner and carefully release the flap to reveal the toner drum - if that is scored and the lines correspond to those on the print-out thats the cause.
Rgds Colin
SOURCE: I have sparkled vertical lines of color on my Sony
the lcd controller is a seperate part that can be replaced you don't have to replace the whole panel if the controller is bad
SOURCE: Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
