SOURCE: wifi not working
check your wireless key or try a new driver from dell here
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
SOURCE: Ipod wifi button is greyed out unable to access help please!
me too. i have the same problem but what you need to do is go to any apple store and get it replaced it was maybe caused by a liquid spill.
SOURCE: when i bought my samsung s5233s wifi @ first i can
may be ur gprs has been deactivated ..check following: 1. is ur GPRS service activated ???? if not activate it by calling customer care of ur service provider. 2.All the connections settings like tha access point name ,ip address , port no ,homepage etc .u can also get settings by msging to ur service provider.
SOURCE: DIR-615 , power led blinks always, wifi and internet not working
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
5. check the power adapter it may be faulty.
Testimonial: "well thanks a lot,actually 1st 4 options i had already tried & it didn't work,the only option i was not aware was 5th one,looks like it will work :)"
SOURCE: Brand new sylvania synet07526-r,Will not
Even a new computer needs updates, the driver and software is only as up to date as it was when the laptop was first manufactured. Try plugging the laptop in wired and go to Sylvania
