Heating & Cooling Logo
S
Steve Tidwell Posted on Mar 20, 2019
Are any parts available for the HZ-709-WMT air hrater? I need 2 wheel supports. Are they available?
1 Related Answer
Anonymous
  • Posted on Mar 27, 2013
SOURCE: My Honeywell HZ 709 WMT stopped working. I've had it for about a year now and has been great up to this point. Any ideas?
Awesome, I just shook mine around a bit in the upright position and its working again.
Fell over wont turn on Honeywell radiator heater HZ-709-WMT
It has a tip-over safety switch that needs resetting according to this
https://www.fixya.com/support/t1749282-honeywell_oil_heater_fell_over_its_side
The manual just says, place it upright and press the power button. Contact details are on Page 6.
https://www.manualslib.com/manual/388934/Honeywell-Hz-2030-Safety-Sensor-Heater.html?page=5
Model hz709 manual
Was there any physical damage to the heater when it fell over?
The HZ-709 has safety features that might prevent its subsequent operation.
1 - It has a tip over switch but the heater should operate normally when it's upright again.
2 - A thermal cut-off fuse will permanently shut down the heater should it operate at a higher than normal temperature. Was it operating when it fell over, or could it have overheated?
If it's none of those, try contacting the manufacturer Kaz directly by email, Facebook, Twitter, etc. as the HZ-709 has a 3-year warranty.
Digital Electric Radiator HZ 709
2answers
I am having the same problem. I am not sure the cause but I was reading that some manufacturers will put automatic shut off switches in the electronics. I read that it was mainly printers and faxes but I wonder if that could hold true here as well?
1helpful
Heater will not work
chelk the mains cord,chelk the voltage in the heaters element if no then chelk the heat aduster(thermostate) if current is available on element then your element is burnt replace it.
12helpful
3answers
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual you need. Hope it helps. If you need anything else, let me know.
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
7helpful
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
That is the manual that you need. Hope this helps. If you need anything else, let me know.
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Top Heating & Cooling Experts
Paul Carew
john h
