Lands Phones Logo
H
Haider Hussain Posted on Mar 20, 2019
My Gaoxinqi Hcd399 set Volume very Slow - Lands Phones
GAOXINQI HCD399(101)P TSDL catalog in english
We have no catalogues.
Please ask whomever or whatever this is directly.
If this is a camera, try your search engine of your computer.
Jan 11, 2018 • Cameras
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
How to change tone and pulse dialling mode in Gaoxinqi Telephone set
Not knowing what model you have, I can't even find a manual for this. Be aware that new phones can't be set to pulse dialling, because the providers are all digital now.
2helpful
I want to change my gaoxinqi set from puls to tone
HOLD (*)STERICK key for few seconds until it displays TONE on the screen. :-)
Sep 16, 2011 • Cell Phones
1helpful
2answers
Apple Ipod voice problem
hi
i had the same problem with my ipod and the volume limit control had been set to playback at low volume...if you have the ability to change settings try this ; when ipod switched on , go down to "settings" and click on this and then select "volume limit" ; click on this and then use the wheel to set the maximum volume you wish to use ( i set it at about 80/100 to ensure no distortion) hopefully this will solve your problem
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
