More than likely several different powders & several different loading, depends on what "Your " firearm likes.
First place to start would be a couple different loading manuals, compare published loads, start low & work up always looking for sign of high pressure.
aIt is a very bad & very dangerous thing asking for load advice on the internet. Never, Never, Never take as gospel any load from the internet. Do your research, check your manuals, if it seems viable, well your on your own..
Best of luck, Take care & be safe..
SOURCE: Sirs
sounds like it could be the scope more than any thing but shoot at 100 yd 5 shot group and see if it groups if if shots dance around on target make shure your mounts are tight there is time that companys send screws for the mounts that are to long for the holes that are taped in the gun the mount mite feel tight but could have play yet witch make your gun not shoot well you could also try setting the scope on 4 power shoot a shot at 50 yards then crank it up to 9 power shoot a shot if bullet impact moves it is the scope hope i helped ya out and good luck
SOURCE: can a regular 22 rifle shoot 22 magnum bullets?
Sadly no as most magnums are approx 3/8th inch longer than lr. Also mags could ruin the rifling.
SOURCE: beemans sportsman rs2 trigger system not engaging after the break barrel been bend goes blank
Do you mean that you have never been able to cock the rifle ever
Like get the piston to lock up to the sear if so
Return to where you purchased it and get them to sort it
Information about the .30-30 Winchester rifle cartridge from Guns and Shooting Online. ... .30-30 Winchester have included 150 grain and 170 grain flat point bullets of ... a premium Supreme factoryload with a 150 grain Power-Point Plus bullet at ... Marlin and Winchester lever action rifles ride in a straight line, with the nose ...
