Televison & Video Logo
My Michelle Posted on Mar 20, 2019
I can't get video to stream from my Android to my visio VA19L HDTV10T. I am using a micro to hdmi cord.I should just be able to plug it in & see what's on my phone on my TV screen. Only get no signal
Is there something wrong in my settings? Input source is Hdmi1, correct?
5 Related Answers
A
Anonymous
  • Posted on Jan 18, 2008
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
jason
  • 905 Answers
  • Posted on Oct 07, 2008
SOURCE: component input- no audio/video signal
copy protect circut may be going bad or the component cicut has now failed
Anonymous
  • Posted on Nov 03, 2008
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Anonymous
  • 3 Answers
  • Posted on Mar 19, 2009
SOURCE: cant find HDMI input on tv, trying to hook up ps3
hdmi output is" INPUT 1" on the menu ALSO hold down on the ps3 power button for 6 seconds and it should come on. the ps 3 has a thing were you have to set it to send out in hdmi or comp.
Dennis McCollum
  • 137 Answers
  • Posted on Apr 19, 2010
SOURCE: Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
3answers
How do I use a Memorex HDMI streaming device with mobile data
Simply plug in the adapter to the HDMI port on your TV, connect it to Wi-Fi, and let the fun begin. Compatible with Android, iOS, MAC and Windows, the adapter is easy to use and makes your connected device your remote for simple control over what you're watching. Stream on!
https://www.menards.com/main/electrical/home-electronics/small-electronics/memorex-wireless-hdmi-streaming-device/mwd38b/p-1529821700089.htm
Can I hookup my computer to my Visio TV D32f-E1? If so, how?
You will need a HDMI cord and you will plug that into the computer and then into the USB on the tv.
2answers
I need to know if I can use a MHL adapter to connect a Samsung S5 to my Westinghouse VR- 4090 tv?
No need to use MHL your phone is capable of casting without wires to your Walmart TV
you need to buy chromecast see links below it amazing
The Google Chromecast is a cheap, simple way to stream video content right to your TV. the $35 Chromecast plugs into your TV and grants easy access to multiple streaming services, from Netflix and YouTube to Hulu and Google Play. You can even throw content from your Chrome browser to the big screen.
see the links below How to screencast with Chromecast
Hooked up to netflix to phone and TV yesterday and all worked fine. Today tried it and it won't play on the TV will only play on the phone. How do we fix
Google Chromecast HDMI Streaming Media Player (2014 ...
www.walmart.com/...Chromecast-HDMI-Streaming-Media-Play...
Walmart
Rating: 4 - ‎1,760 votes
Buy Google Chromecast HDMI Streaming Media Player (2014 Model) at ... This plug-and-play media player allows you to cast your favorites from Netflix, ... It automatically updates to work with a growing number of apps. ..... I love not having to put my laptop next to the tv and hooking up hdmi cords to play .... Mobile apps.
Google Chromecast: What Is It and How Do You Use It ...
techforluddites.com/google-chromecast-what-is-it-and-how-do-you-use-it/
Dec 16, 2015 - The Google Chromecast is a streaming media player, which means it... But there are many other top content providers that work with it as well, includingNetflix, Hulu, .... and use your television remote (NOT your Roku remote) to switch to that ... I set mine up using the Chromecast app on my Android phone.
5 Easy Ways to Get Netflix & Other Video Streaming ...
www.techlicious.com/.../5-easy-ways-to-get-netflix-video-streaming-serv...
Feb 27, 2015 - For laptops, just plug it into your TV with an HDMI cable. ... GoogleChromecast to top-of-the-line Roku 3, Apple TV, and Amazon Fire TV. ... To decide which one is best for you, you'll want to not only look at the features on offer, but to also ... Here are the best streaming media players on the market today.
How to set up a Chromecast - CNET
How I hook up my mhl HDMI cable to my vizio eco 1080p?
Essentially one end of an MHL cable will plug into the micro USB port on your phone or tablet while the other will plug into an HDMI port on a television (or monitor) and your phone's screen will then be mirrored on the external screen.
You obviously need an HDMI port on your VISIO which, if fitted, will normally be on the back of the VISIO unit next to other connection ports. If you have a much older Visio which does not have an HDMI port fitted by the manufacturer then you cannot use an HDMI cable obviously.
1helpful
Can I hook my tablet thru my wifi router or my cable box to stream internet TV on the big screen?
easiest way to stream to tv is with a cable. depending on the make of the tablet , you can buy hdmi micro cables to connect to tv. doing it wireless you will need a box plugged into the tv that has DNLA capability. both are available to buy.if you go for an android tv box they have that but also have XBMC which will allow you to watch any movie/tv programs/sports etc for free
After I select HDMI 2 , Amazon prime will not load. It used to.
Unplug the device from HDMI 2 and remove the power from it. After 5 minutes, plug the HDMI cable back in to port 2 and then plug the power cord in. Hopefully this will allow you to use your streaming device again.
I have Samsung galaxy avant which would be the correct cable or adapter so i can watch the videos i have on my cellphone on my LED FLAT SCREEN
A micro hdmi cord. This has a full sized hdmi male plug on one end that plugs into your TV. The micro hdmi will be the other end of the cord which plugs into you\'re phone. Get it at best buy, radio shack or Walmart. If you go to Walmart however and can\'t find it, do not ask for help.
Oct 31, 2014 • Cell Phones
What cord to get so i can used Chromecast
If your TV is newer, then it should plug into a USB port on the TV. If you aren't sure contact google for help.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
