Depends on model. Try whirlpool site, enter model number for specific model instructions.
http://www.whirlpoolwaterheaters.com/support
SOURCE: water is hot on both
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
SOURCE: Weird taste and smell in water from cooler
Use a 50% mix of white vinegar and 50% water. Pour it in ans run a little through to fill the tubes. After 15 minutes, rinse it with plain water. Next, do the same with unscented clorox. 1/4 cup clorox to 1 quart water. Rub any areas you can reach. The vinegar will melt away mineral deposits and the clorox will kill any mold and mildew spores that are causing the stink.
SOURCE: need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
SOURCE: I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot Possible Causes: Dispenser is unplugged Solution: Push plug completely into outlet Possible Causes: Heating switch not on Solution: Check to be sure heating switch is turned to ON Possible Causes: The fuse is blown/circuit Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker. 2. If too many items are plugged into a single circuit, move some items to a different circuit Possible Causes: Temperature limiter tripped Solution: 1. Set the hot and cold power switches to OFF position. 2. Wait five minutes, then set switches to ON position. 3. Wait 30 minutes for water to heat or cool Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
SOURCE: i have a 2 year old whirlpool water cooler that no
I hope this doesn't sound insulting, but there is a switch in the back that controls uniquely the hot water, is it set to on?
Lisa coolers similar to yours=> Whirlpool Dual-Temp Top-Loading Water Cooler
It appears that customers gave a not so good review yet being inexpensive this is common when most products are imported from China. The WHKM-D10 that you have now is now called the WHKM-10DP Whirlpool Dual-Temp Top-Loading Water Cooler with Heated Water. Wish I had better news, but please keep me in mind for any other Whirlpool, Maytag, Kitchenaid, Jenn-Air, Amana,or GE Home Appliances, Thanks, John Tripp/AKA Sea Breeze
http://appliance911seabreeze.com/
Whirlpool Factory Technician You also can find a user manual by clicking here=> Whirlpool Product Literature; Manuals, Guides and Instructions
position.
