SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
SOURCE: Wiring Diagram for Starter on a Kohler Command 27 Engine, All wire connections for Starter
Large post , battery connection . Small blade connector , should be purple , will be hot when starter engaged ... black will be ground for solenoid if so equipped , does not matter how blade connectors are connected .. some have only one blade connector ...
