Lands Phones Logo
Ringer is off and I cant figure out how to turn it back on..Help please
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on Jan 26, 2008
SOURCE: uniden 2.4Ghz
You can get the manual on the Uniden web site. Here is a link to the page for cordless phone manuals. Just look for your model # and click it. It will then open a pdf format of the Owners Manual.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Anonymous
  • 43 Answers
  • Posted on May 10, 2008
SOURCE: trying to change night ringer voicemail
Ok. You will have to find someone who has access to system manager, or has system manager rights for their mailbox.
They will then be able to select System Manager Options, then Change the Greetings. It will tell you which mode you are in, and ask you if you want to change to Holiday Mode. The responses are 1 for YES and 2 for NO. Say no to Holiday Mode, and then it will go thru Day Mode and then Night Mode, playing each one first then asking if you want to change it.
If you must call in a service order with your phone system vendor, make sure he/she not only assigns someone's box with manager access, but also creates a back-door box with manager access. This way you won't be messing with the original Manager Box. It gets expensive having NEC decipher the Manager's password if it gets changed and no one remembers it.
Anonymous
  • Posted on Aug 19, 2008
SOURCE: how do you turn off the ringer
On printer control panel, select setup, then select #4 (basic fax setup), then #6 (ring & beep volume). Select OK, then press either the left or right arrow until "OFF" appears - then press OK. This will turn off the ringer for the fax machine and will also silence the keypad tones.
Dave Ellis
  • 84 Answers
  • Posted on Feb 27, 2009
SOURCE: Can't get phone to ring
No problem, just push the volume up key untill the ringer is at the level you want it.
Anonymous
  • 371 Answers
  • Posted on Apr 18, 2009
SOURCE: My son turned off the ringer on our uniden
Pick up the handset and underneath the handset is an off on switch for the ringer
Handset ringer switch
This switch turns the handset
ringer on or off.
Page 20 of the manual
EXAI985HS English 2,578 kB Product Details
2answers
3helpful
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
1helpful
2answers
Ringer does not ring on one phone
Well it depends on the model, Most of them you can adjust the ringer volume by pressing the volume up key while the handset is onhook (not in use)
1helpful
2answers
Change the ringer
go for .. the menu and setting phone setting then ring setting..........
The ringer is off and I don't know hoe to turn it on
I have two uniden phones 2.4 GHz and the ringer is turned off and we cannot figure out how to turn it back on again. Please help!!!
My son turned off the ringer on our uniden portable phne and I cant figure out how to turn it back on. Chris
ringer on or off.
Turn ringer on T7316
T7316 Manual
The volume control adjusts the handset, hands free, headset, and ringer volume. Someone may have fiddled with the buttons and turned the ringer down enough that it doesn't sound when a call is incoming.
15helpful
2answers
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
40helpful
How do you turn off the ringer
Phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
