SOURCE: Manual or parts list for Moto-Mower Front Tine Tiller Model 500
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
SOURCE: how do i change ball bearings on tiller shaft
Hello mikeant2:
Usually Heat and a Press/Puller are Required to Remove the Bearing from the Shaft. Sometimes I have even had to Cut the Bearings Off with a Die Grinder.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
Sorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
SOURCE: craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
SOURCE: 2 cycle Murray Ultra front tines, quit pulling,
I had the same problem. It turns out the gear box was bone dry.
Remove both the left side tines, there is a grease fitting below and
to the right of the tine shaft. Before adding grease remove the air vent screw
which is located above and a little to the left of the tine shaft.(It has a slotted head)
Pump in grease until it comes out the air vent. Replace the air vent screw and the tines.
It appeared to me that there was probably never any grease in it
as it took quite a lot to fill and when it finally came out the air vent it was
new grease, not discolored like you would expect to see when you
would be pushing some old grease out with the new.
