Televison & Video Logo
M
Mary M Smith Posted on Mar 19, 2019
Where was the stargazing scene shot in the Aimovig commercial currently running on television
My Nikon D 5200 when in scene mode will not change to other scenes
The scene modes are not apparent when viewing the shot. The scene modes adjust the exposure to help give you the results that particular scene is designed for. For example, the man running is to stop motion. The sets a fast shutter speed for you to help stop the action. You can’t see that happen before you take the picture. The portrait mode sets an open aperture to help blur the background. Etc.
1helpful
"macro is invalid" is displayed
This error message indicates that the current scene selection mode is not compatible for Macro shooting.
Please check the below figure to view the applicable scene selection modes for the Macro shooting mode.
The macro is not applicable in Landscape, Twilight and Fireworks mode.
You can use other scene selection modes with macro mode.
Thanks for understanding.
I hope the information helpful, if you want any clarification, please let me know.
2helpful
Short crackle sound emits from speaker during scene changes
Actually, it is a failing component. Quick scene changes often place demands on the power supply. I would guess that the noise is more prevelant when the scenes change from darker ones to lighter ones. Since this set is so new, request a warranty exchange. This set needs to be serviced. Return it to the place of purchase and ask for a replacement. Usually if the set is less than 30 days old, they just exchange it for you.
Dan
1helpful
Sony cyber shot dsc-t70 unable to change flash setting
The Flash Off setting is fixed and cannot be changed if you are using one of the following modes:
  • High Sensitivity, Twilight or Fireworks Scene Selection
  • Burst or Exposure Bracket REC Mode
If you are using one of the above modes, change the setting to regain flash control.
NOTE: If using Scene Selection modes, the ISO setting is also fixed to ISO AUTO .
Panasonic Color Rings
It sounds like you have a warped shadow mask in your picture tube if your set uses a picture tube. A shadow mask is like a screen wire that lets the three color guns shoot electrons to their respective phosphor dot on the screen to produce the three primary colors which are mixed properly to produce the scene that is being shown. In other words you have a bad picture tube. Stargazer
DVD Malfunction
If cleaning the lens doesn't help, you may have to try cleaning the slide that the laser assembly slides on. This would require taking it apart. When the DVD is inserted, the laser must read the index. If it can't then you get a "no disc" message. If this fails then the laser pick-up assembly may be bad or you have a problem on the circuit board. Stargazer Stargazer
5helpful
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Commercial skip/blackouts
Sounds like you're blessed to have a tv like that! Seriously: Some sets have settings that will cut down the sound during a commercial. Haveyou looked at your owner's manual? This tv may have setting to cut out the picture also when commercials come on. From a technical view point generally commercials have stronger signals than regular programming. This may be overloading your set. If this is the case, then you need to have it checked by good technician. A poorly operating power supply (not regulating properly) could possibly cause a problem like this. Also automatic gain control circuits could be not working properly. Stargazer
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
