SOURCE: Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
SOURCE: allen wrench size to fit caliper mounting bolt
some are 7/16 and some are 3/8 amd some are torx
SOURCE: I have a single -handle
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
