SOURCE: Apple Ibook G3 connect internet through Ethernet??
For Linzie:
To connect to Internet with cable:
1. Turn on your computer.
2. From the Apple Menu, select System Preferences, and select the Network icon. Click on the Built-in Ethernet connection, and then click Configure.
3. The Show drop-down menu should be set to Built-in Ethernet.
4. Click on the TCP/IP tab.
For Guest: Does your iBook 3G have an Airport card?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Ibook G3 not conecting to internet
that just means it cant find it you need to try other setting and create a network connection,
it should see the network cable straight away try diff port on the router then dial up the ip address of the router first and change the setting . ip like 196.162.0.1
actionmab
SOURCE: connecting ibook to linksys
- If your router has an encryption, make sure you were using the WPA.
SOURCE: what else do i need.......bought airport card. not sure what router I need and if I need an adapter?
Hi I'm mhel, you have to buy a wireless router and a hub to connect both your desktop and laptop
mhel
[email protected]
SOURCE: i just bought a graphite clamshell apple iBook g3
If you have wireless in the house, turn on the airport in the contol panel then find your network and away you go.
