What does a poor line condition error mean
These errors are usually related to interference, static, or noise on your phone line. Here are some steps to troubleshoot and resolve the issue:
Check for a dial tone:
1. Press the Hook button on your Brother Intellifax 2820 and listen for a dial tone.
If there is no dial tone, press Hook again and proceed to step 2.
If there is a dial tone, press Hook again and move to step 4.
2. Verify telephone cord/line connection:
Ensure that your telephone cord/line is correctly connected to the port labeled LINE on your machine (located on the lower left side).
If the cord is already in the LINE port, proceed to step 3.
If it's connected to EXT, remove it from there and connect it to the LINE port.
Press Hook and check for a dial tone.
If still no dial tone, proceed to step 3.
If there's a dial tone now, move to step 4.
3. Test with a known working telephone:
Disconnect the telephone cord/line from the LINE port on your machine.
Connect it to a known working telephone and test for a dial tone.
If there's no dial tone, the issue is related to the telephone line or wall jack. Contact your telephone service provider.
If there's a dial tone, reconnect the cord/line to the LINE port on your machine.
If still no dial tone, consider warranty and service options.
If there's a dial tone, proceed to step 4.
4. Remove splitters or other devices:
Check if you have any splitters, commshare devices, credit card machines, or power strips connected to your machine or the telephone wall jack.
If yes, remove them for testing purposes.
After removing any devices, continue to step 5.
5. Adjust Compatibility settings:
Press Menu/Set.
Navigate to Miscellaneous > Compatibility.
Choose Basic (for VoIP).
Press Menu/Set and then Stop/Exit.
6. Send a fax:
Insert the document face down in the Automatic Document Feeder (ADF).
Adjust paper guides to fit the width of your document.
Enter the fax number using the dial pad.
Press Fax Start.
Remember that testing the Brother machine on a different, known-working telephone line can help determine if the issue is related to the machine or the telephone line. If the problem persists, consider contacting Brother Customer Service for further assistance.
If you feel the need to seek another machine, assess the features you need and your budget. Here are possibilities: here are some reputable brands and their models to consider:
Epson WorkForce WF-2750DWF:
This all-in-one printer and fax machine offers economical ink usage and a convenient LCD screen.
Features: Print, copy, scan, and fax.
Scan resolution: 1200 x 2400 dpi.
Dimensions: 16.73 x 14.17 x 9.06 inches.
Weight: 14.55 lb.
It's a budget-friendly choice for home and office use.
Brother MFC-L6800DWT:
A high-speed monochrome laser fax machine with additional features like printing and scanning.
Ideal for small offices.
Check out its performance and ease of setup.
Canon TR8620:
A multifunctional all-in-one printer, copier, and fax machine.
Offers versatility and functionality for various tasks.
Consider it if you need a reliable fax solution
