Patricia, Yes. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Amazon update your old Kindles or youll be cut off from the store
their are 7 recalls on the 07 none are for an electrical problem with lighting system http://www.pontiacproblems.com/recalls/G5/2007 and the following tsb from march 2010 is for flickering lights
Summary: CHEVROLET/PONTIAC: VARIOUS ELECTRICAL CONCERNS. SIR LIGHT, IP LIGHTS FLICKER/INOPERATIVE, PARKING LAMPS FLICKER/INOPERATIVE, TAIL LAMP DIM/INOPERATIVE, TRUNK OPEN LIGHT, RADIO INOPERATIVE DOOR LOCK INOPERATIVE, NO START, NO CRANK. POSSIB More Information »
Summary: CHEVROLET/PONTIAC/SATURN: ENGINE FAILS TO START AFTER ENGINE CRANKS DUE TO FUEL PUMP WIRE HARNESS CONNECTOR NEEDS REPLACING, WITHOUT REPLACING FUEL PUMP COVER ASSEMBLY (FUEL PUMP FLANGE). MODEL 2007-2010 COBALT, G5, ION. *PE More Information »
just had the same problem with my husy 357xp all i done was push the kog back onto the handle and pull the handle back to release the brke and fit cover back on with no other problems. If this does not work a pair of pliers or grips and turn the kog by hand this is very hard but can be done hope this helps
