SOURCE: engine cutting out with the choke off
Adjust your idle screw on your carb so that it gets more gas just sitting there at idle. Tighten the screw one and a quarter turn and then start the bike. Adjust the idle to where you think it sounds normal. If that doesnt work check your float in your float bowl, it might be stuck in the down position. Clean with some carb cleaner spray and make sure it moves freely before putting the float bowl back on, youll have to choke it or prime the carb again to get it started. All the choke does is let in more gas and oxegen so you might want to check how far the carbs close when you push the choke back in. Is it impeading any normal carb setting. Check that too. Good luck.
SOURCE: I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke
all 3 carbs had A clogged jet totally dis assembled and cleaned the carbs put them back on and the engine runs great I will need to fine tone the needle valves once I put some fresh gas in it.
Thanks
John
SOURCE: Yamaha TTR 125 L won't idle
i cleaned the carb on the bike and put it back together and now it is as if the float is stuck open and is just dumping gas out of the carb all over the ground.
SOURCE: bike idles on choke , engine dies on acceleration drz 400 e 2003
try using that redex stuff get back to me
SOURCE: My ryobi pbc-3046YE brushcutter wont run.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
