SOURCE: water leaking from the bottom of the humidifier
Make sure the bottom port on the humidifier is seated properly in drain port. Make sure your drain line is not obstructed.
SOURCE: crane penguin humidifier
This is the link to your manual:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Hopefully the manual helps you getting it to work. If not come back and give more info about the problem.
Good Luck.
SOURCE: anyone know where i can
I have an elephant humidifier with a broken fan. I just posted the problem, but I doubt there is a solution. I'm sure the tanks are interchangeable from looking at the manual, if you don't mind an elephant (I don't know if the lid is interchangeable). I would hate to throw it out and have one more thing in the landfill. Maybe I could send it to you?
SOURCE: the red ligt on with water inside
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and
not turning green
Humidifier is working than stops:
? Ensure that water level sensor is
assembled properly.
? Clean water float
? Call service center and request
replacement water float
