SOURCE: 2004 pontiac gran prix gt
I would suggest replacing the blower motor resistor. When this component fails the blower will only work on one spped or none. This is a very common issue with all automotive models
SOURCE: Heater problems on my 2000 Jeep Grand Cherokee. Please Help!!
THis is a know problem with Jeep GC. If only one side is cold and the other is hot and there are no controls error codes. It is likely a broken temperature blend door on the faulty side (w/ dual controls). Dealer charges a lot to fix ~$800. There is a kit and instructions sold on EBAY to replace the part for $100. Seller claims that a relative novice can fix w/o removing the entire dash board as the dealer does. Has sold hundreds of kits....people seem satisfied....you may check it out. Search Heater Blend Door Jeep on ebay. Replacement parts are aluminum instead of OEM plastic.
Self Diagnostics on HVAC system. Jeep GC has built in diagnostics and will return error codes on the temp display if it is otherwise. Simple to display.
1) Press A/C and Recir button simutaneously
2) Rotate driver temp control knob clockwise then release buttons
3) If no controls error a code of "0" or "00" will be returned.
4) Error codes listings can be found on-line if anything but zero
Dealers charge $45 to run the same check
SOURCE: driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
SOURCE: heater blows cold on 02 chevy silverado 1500 4.3 V6
i had the same problem with my 2000 chevy truck!! i took both hoses off engine and flushed the heater core with water and air frome air compresser,added new coolent and it works perfect!!!! so try flushing your system............
