SOURCE: BUSTED FUSE
A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs.
SOURCE: Magellan Maestro 4250 GPS Power Failure
Hi guys. No need to panic. I thought I had the same problem when I got mine but actually there is no problem. Somehow, the off-on switch on the system is kind of funny. U really have to have small finger and depress the switch as far as u can until the system comes on. Might not be the fix you're looking for but give it a try anyway. Nothing to lose. Good luck.
SOURCE: Wont turn on; remote/tv power switch inoperative
hi I am Vortash .. burning smells usually mean Power supply or line output .. flyback problems .. this is probably one of those jobs only an engineer should look at .. voltages on the line can exceed 400 volts and are highly dangerous the line output from the transformer depending on the type of tube can be up to 25,000 volts .. so best leave this one to the proffesionals Regards Vortash
SOURCE: power will not turn on
If you know the outlet is good then you need to unplug the AC slide it out of the cabinet and see if the on off switch is working or if there is a loose or burned connection in the wiring circuit. check all wiring going and coming to capacitors and check to see if the continuity between the post on the control switch. There are many different models and each one has different features. So each one may be wired a little different. While you are inside the cabinet mart the wires going to compressor and where they connect. Let me know when you get to that point and I will lead you through the way to test the compressor. I don't think the compressor is the problem, I just want you check all connections for burns or bad connections, Thanks, Sea Breeze
SOURCE: can a RCA universal remote work on a Bose Stereo?
Try this site:
http://www.remotecodelist.com/remotes/
