SOURCE: BROKEN COVER HINGE
http://www.precisionroller.com/find/brother_dcp8025.htm
Replace hinge yourself, purchase link above
SOURCE: Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
SOURCE: Whirlpool ice door flap pivot pin tab broken
I have a Whirlpool side by side, model GC3SHEXNT03 that had the plastic hook that holds the ice door pivot pin. While we can question why they make it out of plastic given the number of posts I've seen with people having the same fear that I had....Replacing the whole darn door to fix 1 little piece of molded plastic. I found some posts about an Ice Door Repair kit, but wasn't sure if it would fix my issue. Luckily I live about 8 miles from the RepairClinic.com warehouse in Michigan, so I went to talk to them to see. Nothing in the discussion was definative, but the have a 30 day return policy so I bought the kit for $74 (ouch!) and it worked beautifully. I have an ice dispenser once again. I know what some of you may be thinking...I work for them....Nope, I'm a computer techie that HATES paying repairmen!! And I'm posting this in the hopes of saving someone the 2 weeks of Googleing that I did trying to find a solution, short of replacing the door. Here is the link to the kit, I hope it helps somebody out there.... http://www.repairclinic.com/Appliance-Parts?s=t-8201756-%3d%3d should be Item #1164531
SOURCE: Hinge for the Cartridge Door will not latch. Seems
good old duck tape ;) or go to a print repair shop and see if they have and parts for you.Ink shops sometimes do there own repairs too so try there
Testimonial: "Thanks I did not know the Ink shops could do repair. "
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Laptop hinges are generally
made of low-cost metal alloys, or "pot metal yeah this may cause problem you can fix your broken hinges easily by spending little time ." Pot metal is not
particularly durable, and over the course of a laptop's life cycle, repeated
opening and closing of the computer's lid can cause wear that prevents the lid
from staying in an open position. Hinges can also wear to the point that they
break at the point of attachment, either on the lid or the computer's body.
Hinges are usually attached to
the computer's frame via machine screws. In order to get the most life out of
your computer's hinges, it is not a bad idea to perform a yearly inspection.
Remove the hinge covers and check that the machine screws that secure the
hinges are tightened fully. If screws are missing, contact the computer's
manufacturer to order replacement screws; hinges missing screws are subjected
to additional stress and can wear out faster if steps are not taken to replace
the screw.
Lubrication of the hinge is possible, but not recommended; if the wrong type of
lubricant is used, it could damage the computer's case or seep into the
electrical components and further damage the computer. Consult a professional
technician if you feel that your hinges require lubrication.
o Hinges can also be damaged when
the computer is picked up by its lid, dropped from various heights or opened
beyond the angle at which it should stop. In these situations, damage to the
hinges may be of secondary concern, as component damage and data loss might
have occurred. Depending on the amount of damage and warranty status, the
computer may require complete replacement.
Laptop hinges are not
indestructible, but their coverings and trim may show wear long before the
hinges are actually in any danger of failure. Most laptops on the market
include plastic hinge covers. The hinge covers can develop stress fractures
from repeated wear; most of the time, this is not indicative of a hinge
problem.
Some laptop hinges are housed within the bezel or trim of the computer's
monitor or body. This, too, is generally made of plastic, and might develop
stress cracks after a few years of use. Hinge covers and bezels are usually
modular, and replacements are generally easy to find at low to moderate costs.
Repair
o Hinge problems can be mitigated
with adjustments to the hinge's tension or additional hardware installation by
the user. Brackets can be installed on the outer case to allow for hinge-like
performance, or the screen can be mounted in a fixed position. If the screen is
left permanently open, care should be taken to prevent damage to the screen and
to prevent dust accumulation in the keyboard.
The lid and screen assembly can also be replaced, if the correct parts can be
found. Replacement of the lid and screen can be cost-prohibitive, with parts
and labor sometimes exceeding the cost of the computer.
