Televison & Video Logo
D
Doug Graven Posted on Mar 18, 2019
Samsung 654 kuhuddhd r smart 6000 tv started going off and on about a month ago . Purchase 1/18/19
1 Related Answer
james ayers
  • 170 Answers
  • Posted on May 17, 2014
SOURCE: I have Samsung UE55F9000 UHD smart TV bought only two months ago, when switch it on SMART TV screen appears and its shuts off and goes blank completely. Red switch light keeps flickering on and off. A
Check power cord is plugged in all the way.
2answers
How to download Google chrome on Samsung smart tv?
I am assuming you want to use Chorme the browser.
Most Samsung Smart TV (Like the Samsung 6000 series Smart TV from 2013/14 have Chrome built-in.
What is your model and year ?
In older units, not sure if it is possible. In the older TVs even if you try to install the app from the browser on the TV. Unfortunately perhaps there is not an option to download an alternate browser on your TV.
I have a Samsung UF55F9000AFXZA television and about a month ago it started taking a little time turn on and seemed to take longer each time i turned it on. Now it wont come on at all, but it tries. when...
with the fault worsening slowly it points to failing capacitors on the power supply Board which is not uncommon for this brand, there are many repair kits available for this brands power supply boards if you feel you are capable of fitting them try Here:
TV Repair Kits MBTV Electronics
or you could consider replacing the whole panel, a bit more expensive but less technical expertise required, shop Jimmy is the largest supplier of replacement boards:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Watch netflix with samsung TV
Hi , It is easy to have bbc iplayer or UK or US netflix on Samsung smart TV and watch it outside the UK or US
there are two way to do , one is using DNS ,, but no recommended because it blocked occasionally, so the best way is use reliable VPN provider which you can get from this link http://www.overplay.net/#a_aid=vpnprovider
you can get the account and pay for one month 10 $ or one Year 100 $ VPN + smart DNS , also you can ask for refund if not work for you so you are in safe side!
after getting your account ready , you need VPN Router , and technology of VPN better should be openvpn it is faster more stable than pptp or l2tp because it reconnect if even your main connection drop and restored
once your VPN router is ready , just reset your samsung TV to factory default , you can go to TV manual and do it
connect your TV directly to the VPN Router for your reference connection should be like below
Main Internet Router -----> VPN Router ------> TV
restart your TV and live it for 30 minutes ! vola you will see netflix , Pandoora , Spotify will apear on TV apps , just enter your user name password of netflix and start enjoying it !!! let me know if this helps?
No sound on tv
Unplug your tv for a few minutes might help if it doesn't, turn your tv on, go to menu, reset to factory settings.
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
2helpful
2answers
Sky remote control code for samsung ps43e45/49 tv
The code you are looking for is 1340. I have the same TV and my sky volume hasnt worked since I bought it, (9 months ago).. After spending an age on the SKY forum with no luck, I simply googled (Sky remote codes) and clicked on the 1st site, it's skyremotecodes.co.uk then Samsung 6000 series.... It told me the correct code and gave me clear instructions...... I hope this helps someone else.
Tv started to shut off here and there, then the
Hi,samsung has 3 major failures.The 1st one is the lamp, which averages 6000-8000 hrs 2-4 yrs.When it's about to go bad it shuts off and on or image won't come at all.You can find your part here:http://www.discount-merchant.com/SearchResults.asp?Search=BP9601472A Another problem that causes tv to shut off is the ballast,which is the board that powers the lamp.It makes clicking sounds and will cause pic to flicker.The other problem is the color wheel .The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Have a bless one!
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
