SOURCE: acme 6001 juicer. Excessive vibration and movement during use.
usually the vibrations are caused by improper assembly ( it does not take much ) or the rate of feeding material into juicer. feed the juicer too fast and it gets out of balance.
SOURCE: why is water forming under the veggie drawers
One of two things caused this problem, either the drain in the freezer is clogged and spilling over to the air duct and through to the refrigerator, down the back wall and then puddling up under the drawers or the Styrofoam between the freezer and refrigerator is saturated with water. If you remove the inner back wall of the freezer and there is ice built up, defrost it with hot water and a turkey baster, push some heavy weed trimmer line down the drain tube and they should clear the clog. If there is no ice build up, then you probably have the latter of the two problems, the only solution is to empty the unit, turn it off, and let it dry out for a few days with the doors opened. If the problem continues, then there is a significant breakdown of the Styrofoam between the two cavities and there isn't a solution, it is time to purchase a new unit.
No, unless they are canned fruits and vegetables. Regular vegetables and
fruits will not last for a long period of time.
