On the HP LaserJet 1320, the attention light is a generic alarm. It can mean out of paper, paper jam, paper misfeed, cartridge missing, or cartridge door open. You can try cleaning the pickup roller or changing the separation pad. You can find these maintenance steps in the user manual starting on page 73 (page 83 of the PDF). HP has the manual here: http://h10032.www1.hp.com/ctg/Manual/c00208215 . More guides are available on the product page: https://support.hp.com/us-en/product/hp-laserjet-1320-printer-series/410622/model/410624/manuals . Amazon has the separation pad available here: https://www.amazon.com/RM1-1298-HP-Separation-Tray-P2015/dp/B009SPB1H4 . Links to replacement pickup rollers are on this page. There are probably other sources for the parts as well.
Unfortunately, it can also indicate that a part has broken from paper pickup unit or the door closed sensor isn't working. At my home when our LaserJet 1320 reached ~10 years old, we got this message and decided to replace the printer. It wasn't worth trying to locate and repair the problem when cleaning the pickup roller and paper path didn't work.
I hope this helps.
SOURCE: "cartridge memory error"
To identify the misbehaving cartridge just replace them one by one with another new, preferably HP cartridge. As far as why, HP makes lots of money by ?encouraging? users to buy genuine HP consumables. While HP?s cartridges are uniformly the best available they are are outrageously priced, thus the refill market. In an attempt to kill the remanufacturing market HP now embeds ?chips? in each of their LaserJet cartridges, unfortunately for HP refillers can replace them too. I?ve found several references to this error message and they are always linked it the printer discovering a remanufactured cartridge. In most of the other cases this automatically disables ?economy mode? printing but you can typically bypass the error message by hitting the enter (check) button on the printer.
SOURCE: Nothing printing
I work with Zebra printer on a daily basis and it sounds like you will need to restore the printer to the factory defaults. However if you choose to do this you will remove the network settings, assuming your print has a NIC and you are using it as a network printer. Record the network settings before you default the printer so you have them on hand to re-enter the settings. You will need to enter the Advanced Setup 3 to load the defaults, Once the defaults are reloaded go back into Advanced Setup 3 to re-enter the network settings. This should solve you problem.
SOURCE: epson printer won't print
That sounds a lot like the print spooler has suffered some kind of problem...
Try the following:
Tip: This is the same thing as going to Control Panel > Adminstrative Tools > Services
From here you:
This will restart the print spooler.
If the spooler is the problem you should be able to send a print job to the printer and it should now start printing.
If not then the chances are this is either a port misconfiguration or a driver error in which case you should try:
If the port was misconfigured this SHOULD solve the issue but there's no guarantees... If you're still having issues, post again and we'll go from there..
Hope this helps.
Martin
SOURCE: Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
SOURCE: Samsung ML-2525W monochrome laser printer;
I have the same problem with mine - first job usually prints but no go on the second one. It tells me the printer is "offline". In some cases I can't even power cycle normally. I have to unplug the back cord and plug it back in, then I can power back on.
I called Samsung today 1-800-726-7864 and was told the printer will need to be taken to a repair center for service.
Wish I had better news.
