taking the battery out will do it
SOURCE: lost google username and password cant get on tablet. tried hard reset and nothing happens
lo que podes hacer es ingresar con una nueva cuenta y luego que puedas ingresar cambiar el mail a la cuenta que usas cotidianamente
SOURCE: how do I bypass pattern lock on my Proscan PLT7223G tablet?
Zolygon Factory reset Proscan PLT7223G Android Tablet
Please watch the video and try the link given
SOURCE: how do i reset my tablet
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button,Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished.
SOURCE: How do I recover Google apps and play store to my Samsung galaxy tablet 2, after factory reset,
Go and search it on the Play Store and manually install it.
If it fails try searching on google for an apk of google services and install it on your device.
