SOURCE: MA Audio HK4000D please help me ?
i suggest u look at the spkrs inside the box and see hw they are wire inside the box that could be one your problem[[email protected]]
SOURCE: mono amp
well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
SOURCE: i have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class
X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS
@ 1 Ohm Mono
1 x 650W RMS @
2 Ohm Mono
1 x 500W RMS @
4 Ohm Mono
Fully Unregulated MOSFET Power
Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil. To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series. This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup. Crutchfield does not carry the Kicker L7 in 15" They do have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms.. Do the Same with VC2+ to VC2-. you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
