SOURCE: Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
SOURCE: Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
SOURCE: Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
SOURCE: Rapid flashing green light but no power. I've
1.) Most of these sets have a receiver built into the back(large metal box on left side as you look from the back.)
2.) Two possible reasons for green light constantly blinking(it is the receiver booting up if the set is disconnected from power---light should blink for about 70 seconds and go out).
3.) First reason: The recessed micro switch on the keyboard marked reset may be bad--does not happen a lot but it does happen. Easy way to see if this is the problem is to remove front speaker grill---and inspection plate behind it---from the keyboard you should see one or two groups of wires(they come from the keyboard) follow them to the right and unplug both(they are different and marked with letters). This takes the keyboard out of the circuit---you should still be able to turn the set on with your remote(remote receiver is behind the screen.) IF SET NOW WORKS YOU HAVE TWO CHOICES--USE IT ONLY WITH THE REMOTE OR HAVE SOMEONE REMOVE THE FRONT KEYBOARD AND UNSOLDER THE RESET SWITCH--the switch can be replaced without replacing the keyboard(it is a small circuit board with all the micro switches on it.)
4.) If disconnecting the keyboard does not fix the trouble---you have a problem in the "Receiver"----it happens on these sets and usually is repairable--Mitsubishi no longer sells this part and it was very expensive when they did---if disconnecting the keyboard does not cure the problem---let me know and I can give you options for getting the receiver repaired.
5.) Let me know if you have questions and if you need more advice reply to this post here.
I do this here for free so if this information helps you take a minute to give me a vote here---I am here to help people.
REGARDS, SD TECH
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
