Officially, yes you need a new screen. But what you are describing suggests a solder joint that has become loose. If you can remove the screen and the guts behind it you might get lucky and find a solder joint that is visibly not secure. If you carefully heat that joint with a solder iron, and maybe add a tiny bit of rosin core solder to the joint, you might end up saving $$$. Good luck!
SOURCE: My screen Half Black - Half Red
you have a warranty! the set has a problem either with the panel or the main board take it back to the store where you bought it and exchange it or have it repaired by a factory authorized repair place.
SOURCE: veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
SOURCE: Kettle will not stay on
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
SOURCE: my screen will not work when i touch it but when i
this means the touchscreen does not respond when touched,it seems the outer screen is not sitting properly on the inner touchpad,you might have to consult a qualified technician,because the problem requires care and techniques
SOURCE: white screen on lcd nothing visible but output ok
i think you should try Fn-F5 not F6 hold the button down a while
