please see the video and proceed according, LUBE the rollers bearing very IMPORTANT! However , if the problem persist your must test a) main motor+belt b) main control motor board see the block diagram attached. God bless you
When plugging my treadmill in it was going at max speed without the key even in. Now it has slowed to a complete stop and I can not get it to move. The incline works, but not the speed.
I have a Roger Black Treadmill & it came in 1 piece ready to go. There is no way to dismantle the one I have. Not sure if there are multiple models but I have only ever seen 1
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking
belt is centred.
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
I have a manual for this exact treadmill. Don't have a scanner though. I checked with my local print shop ans they said they could scan it and save as a pdf for $10, if you are interested.
