Https://spares.hansgrohe.com/etk/INT/product/04076000/8809627168611.seam?fsid=0x000077210000704100006F91&lang=en_GB&wcms=INT
https://assets.hansgrohe.com/mam/celum/celum_assets/16__hruh0765_pdf.pdf?5&_ga=2.43849249.583112013.1552939079-215678084.1552939079
The faucet is rated at 6.7L/minute (<2 gal/m) and I would expect that's a design of the cartridge. You could measure flow with spray head attached, then remove head (see link) and measure again to see how much the head reduces rate of flow. You could try removing the check valve(s) but not sure if that will work as it may leak.
product features · consists of: single lever kitchen mixer · swivel range 150° · with telescopic function (330 - 500 mm) · normal and spray jet · lockable shower spray, spray returns through pressing spray diverter · quick connect shower hose · flow rate 6.7 l/min · ceramic cartridge · connection type: G ? compression · integrated non-return valve · suitable for continuous flow water heaters
SOURCE: cross handle hansgrohe faucet I can't remove top piece
Use a rubber glove between the strap wrench and the fixture. It is a little monkey business but keeps the strap from slipping.
Phil
SOURCE: How do I remove knob from Hansgrohe shower faucet?
Depends on the model, there's usually an allen screw holding the knob on, this can be hid under a little chrome cover or under an unscrewable lever.
SOURCE: hansgrohe faucet part-no. 92730000 faucet cartrige
Please contact me at the below number or email and I can supply you with a copy of the installation instructions.
Regards,
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:[email protected]
SOURCE: How do I remove cartridge
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Hansgrohe Inc.
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
SOURCE: stiff cold water handle bathroom Hansgrohe
If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
