Vehicle Parts & Accessories Logo
Dennis Lucas Posted on Mar 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whistler 1010 is a year old, it worked good till unplug now it does not come on like no power , I have a tester and i'm getting power but it does nothing why ?
mike rigsby
Level 2:
  • Expert 58 Answers
  • Posted on Apr 13, 2019
mike rigsby
Expert
Level 2:
Answers
58
Questions
Helped
19998
Points
110
Check and see if there is a fuse in the plug on the end of the wire, sometimes when you unplug those the fuse can blow in them
5 Related Answers
Anonymous
  • 134 Answers
  • Posted on Mar 19, 2009
SOURCE: does not sound alarm till its to late
The lower end Whistler radar detector models do not have particularly good performance against all radar gun frequencies. Whistler's XTR-690, Pro78 and XTR-695 on the other hand do perform very well against all police radar guns. Its basically a matter of you get what you pay for.
Anonymous
  • 65 Answers
  • Posted on Nov 04, 2009
SOURCE: My 3 year old bottom frezer samsung fridge stoped
3 things defrost heater, defrost timer or defrost limit thermostat.
You can pull the cover inside the freezer exposing the evaporator coils,
look for the defrost heater at the bottom of the coils. Test for continuity.
Find the defrost limit thermostat, a 2" metal disc attached to the evap coil usually on the side towards the top has two wires going in and will have continuity only when it is cold. If those are good probably the defrost timer.
Anonymous
  • 2220 Answers
  • Posted on Nov 10, 2009
SOURCE: Husqvarna 345 chainsaw will not start. It is 3
I suspect she is flooded. Flooding is the most common cause of fails to start on a chainsaw. Remove the plug I bet it's wet.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
I've a 359 one time I forgot to pull then push the choke (sets fast idle). My shoulder gets sore just thinking about it.
Anonymous
  • 565 Answers
  • Posted on Nov 08, 2010
SOURCE: Greenlee 1010 tester does not take AAA batteries.
The Greenlee 1010 tester uses #357 watch-type batteries.
InMrFixIt
Rian Peters
  • 121 Answers
  • Posted on Oct 30, 2011
SOURCE: compressor starts slow just like
A lot of common problems in this catagory. Most capacitors show damage at the vent on connector end of cap. Make sure to unplug/disconnect power from both legs of power, at breaker or pressure switch. Good caps retain charge, so you will need to discharge cap befor testing. ground each leg, then short between legs, to discharge the caps. If it sparks it probably is good. If no spark, and no physical damage, you can replace the cap, $4. to $30. each. Most motor repair shops have cap testers. Low's has a good meter for around $27.00. Warning falure to discharge the capacitor, will damage the meter.
I have a whistler pro 78 radar detector and for some reason the audio is distorted. It has been mounted on the windscreen all the time (didnt get wet, nor was it hit). I assume it either has a shortage or...
Its possibly a bad speaker. If the unit is under 3 years old, send it back to whistler to get it repaired under warranty. You can contact them at www.whistlergroup.com or [email protected]
if its over 3 years old, a good chance its just the speaker and you can order a speaker from whistler for $10 and repair it yourself.3eulcg
Whistler xtr 690 voice need to be fix
If your unit is under 3 years old, contact Whistler at [email protected] for info on how to have warranty service performed. If its over 3 years old then you can call them at 800-531-0004 to order a speaker. This assumes that you tried a factory reset and that the auto quiet and City modes are off which basically leaves only the speaker as the possible problem.
4helpful
3answers
Paper jam in hp laserjet 1010
Error 600
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
Our 1 1/2 year old trash compactor will not operate
You may have to get a voltmeter or multi-tester and test voltage from power supply. Check to see if fuse is good. Check wires to pedal and lastly, use capacitor tester and test all capacitors to see if there is a faulty one.
Sound
Holding down the volume button will cycle up and down through the volume settings. Yet I suspect that the internal speaker has finally given up the ghost. This is a pretty old Whistler RD. I would highly recommend upgrading to a modern radar detector which has much better overall performance. One of my favorite current Whistler products for the budget conscious is their Pro78. This model provides very good performance at a reasonable price.
Does not sound alarm till its to late
1helpful
No Sound
whistler wanted $55 to repair this detector, so I bought a different brand and will never buy another whistler again.
Top Whistler Vehicle Parts & Accessories Experts
Ngoro
Arnie Burke
Arnie Burke
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
