SOURCE: top loading automatic washing machine not filling
Check the filters on both sides of the inlet water line. Let me know with your results for further assistance if will be needed. Good luck!
SOURCE: HE3t Kennmore water fill level adjustment?
I completely understand your dilemma as I have the same problem with my HE3. I was so frustrated I called a service tech out before my warranty expired and he told me the #1 complaint about these washers is that they don't get the clothes clean. I was surprised at his honesty! He told me to get a water softener and to use hot water but said nothing about clothes that are supposed to be washed in cold water. I asked him how to adjust the water level and he said the sensor is not adjustable but I have been unable to find out if these is true. I agree with you and believe it's because they use too little water. I have come to absolutely hate this washing machine for many reasons. When washing anything long (jeans, pants, long-sleeve shirts, etc) it literally ties the whole load into a clothes knot. You can grab one item and pull the whole load out because it's a huge knot ball. So tell me, how do the clothes get clean (or properly rinse) when they are in a ball and unable to freely move through the water (which isn't there) in the bottom of the tub? Another problem is that it takes a MINIMUM of 3-4 rinse cycles to get the detergent out of the clothes...yes, I use HE detergent. Here's what I do. I use the 'add a garment feature' to interrupt the cycle after the washer has filled. Then I add about 2-3 gallons of additional water to both the wash and 1st/2nd rinse cycles. This has helped immensely but leads to two more reasons I hate the machine. First, that makes it extremely high maintenance to stand waiting for the moment to add water. Second, when adding the additional water, clothes have a tendency to get caught between the rubber gasket and wash tub where they can sit during the entire cycle not getting clean. On the up side I can say I've never had a mechanical problem with the machine. I am sorry and wish I could help more.
SOURCE: top load Kenmore 800 washer will not fill with water
OK - I have a solution to my problem with this washing machine. Nothing would work except for one of the spin cycles. I thought it was the main switch - the cycle selection and start switch - but I was wrong. The service tech replaced the switch behind the fabric softener. It's the switch that controls the water levels. Part # W10292584. Our government is forcing the manufacturers to put controls on the washing machine to save water. It's a bad idea and is causing lots of problems. Tech says he's replacing them on a regular basis. Less than $100 if you do it yourself. Hope this helps.
SOURCE: low water level in top load washer
Load selector switch has a hose attached to it that goes to bottom of washer tub. It is probably clogged with soap. Open top where switches are, disconnect tube and blow it out. Problem should be solved. The only other thing it could be would be load selector switch has gone bad. But I am betting tube is plugged.
