How do you change a fuse for a Schumacher SE-82-6 battery charger
You do not, there is no fuse. Refer to the instructions that came with unit, for troubleshooting.
https://www.batterychargers.com/sites/default/files/manuals/0099001365-R2.pdf
SOURCE: need manual
So to this site and download it.
http://manuals.batterychargers.com/manuals/00-00-000496.pdf
SOURCE: battery charger- schumacher se 4020
Century Tool and Equipment. $3.99
http://www.centurytool.net/SE_2158_Schumacher_Battery_Charger_Parts_List_s/30946.htm
SOURCE: Issues with Schumacher Battery Charger SE-82-6 -
I have the same one. The black wire from teh ac cord has a white connector that goes on the switch but there are 4 choices. I need a diagram as well.
SOURCE: i have a schumacher se-82-6,i
If you look at the meter, the charge meter of 100% is slightly above the 2 amp mark so it is confusing. because it says the charge represents the amont charged and the amp meter shows when there is no draw on the charger. so if the battery shows 2.5 amp on the amp meter, it's showing 100% charged. but yet they say it should go to zero on the amp meter, which would mean about 150% charged. i think everyone is scared of blowing up or damaging their batteries because the instructions manual is quite contradictory and confusing. well apparantly, they have several versions of this model to make it more confusing, but here's a pic of what i have.
http://www.northerntool.com/images/product/zoom_images/1677820.jpg
ok, as i was looking for manual online, it is more detailed than the one in box. it now explains this in picture detail. thank you schumacher.
here's the updated manual:
http://www.batterysales.com/downloads/SE-82-6.pdf
hope this helps.
SOURCE: need a 3 position switch for a Schumacher model se-2352 battery charger
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
