SOURCE: airless sprayer will not prime
Check for a plunger on the bottom of the machine. Pump it several times and try to prime with water. Also, if there is difficulty priming after trying the plunger, switch on in prime, and cycle to paint, back to prime,paint,prime. After several tries, leave it in prime with the pickup tube in water, and pump the plunger again. If this doesn't help, disconnect the hose fron the pump and try again. If you're getting water now, the issue is down the hose, or at the roller/gun.
Hope this helps! --W/D--
SOURCE: where can i find a instruction manual for a wagner
Goto http://www.wagnerspraytech.com and click on "sprayers" and select your model. If not listed goto "customer service" then "discontinued product manuals".
SOURCE: Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
SOURCE: i have a titan high rider sprayer, that wont
sounds like your pick up line is plugged or restricted and the pump is choking. it needs fluid.
