Washing Machines Logo
K
Ken Reid Posted on Mar 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can’t get the cover over the inlet on my LG top load washer .have removed the only 2 screws and it still won’t budge ??
Stephen Miller
Level 3:
  • LG Master 1,645 Answers
  • Posted on Mar 17, 2019
Stephen Miller
LG Master
Level 3:
Answers
1645
Questions
0
Helped
866182
Points
9471
5 Related Answers
Bob Gemmell
Bobby G
  • 212 Answers
  • Posted on Sep 13, 2007
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
dreeme1
  • 36 Answers
  • Posted on Dec 29, 2007
SOURCE: taking roper washer apart.
Hi, It might come apart like this:
http://groups.msn.com/Appliantology/washers.msnw?action=ShowPhoto&PhotoID=283
Anonymous
  • Posted on Mar 26, 2008
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Anonymous
  • 1028 Answers
  • Posted on Aug 10, 2008
SOURCE: How do you remove the
clips just under front edge and about 3-4 ins from corners press in with putty knife lift top remove screws on upper edge either inside just below top or along top edge
Anonymous
  • Posted on Jan 13, 2009
SOURCE: removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
2answers
LG Tromm front load washing machine WM2688HNM, does lid on this washer remove differently from other LGs? Trying but won't budge HELP SOS!! How do I remove lid to get to inner works of this machine?
You need to remove the front panel there’s 2 screws behind that panel once you remove those screws the top from the front push it towards the back and slide it up at the same time
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
Does anyone know how to remove the top cover of the LG wm-2277 hw after the screws are removed from the back ? Have a water leak up toward the top of machine but cannot reach without removing the top ....
Disconnect the LG front load washer power cord from the wall outlet. Turn off the water supply to the washer at the water spigots coming from the wall.
Pull the washer 3 feet away from the wall, and disconnect the water supply hoses from the water inlet valve ports on the back of the washer. You may need a pair of channel lock pliers to loosen the hose connections.
Remove the screws securing the back of the top panel to the back of the washer with a Phillips-head screwdriver. Depending upon your model, you will have either two or four screws to remove.
Lift the back of the top panel up, and slide the top panel toward the rear wall, which will unhook the top panel from the clips securing the panel in the front of the washer. Lift the top panel off the washer and out of your working area.
4helpful
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
Water Inlet Valve Replacement Procedure
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
4helpful
2answers
How do you remove the top on a LG WM2077CW front loader?
I can not remove the top cover of my LG WM-2277HW
can somebody tell me how to lift off the top cover. I already
removed the screws from the rear
HOW DO YOU REMOVE AND REPLACE WATER INLET VALVE ON FRIGIDAIRE LTF2140FS1
remove the screws holding the top panel on, they are located on the back at the top. Standing at the front of the washer, push top panel towards rear, then lift up and remove. Notice the water inlet valves on the rear left while facing the washer front. Unplug washer, then remove the mounting screws holding valve assy onto machine, on some fridg's there are 2 screws holding an inlet valve assy onto the dispenser underneath the valve assy, they are very hard to get to. Remove valve assy from washer and replace. Remember to mark wiring locations as needed.
How do I remove the top of my LG WM2496HSM washer?
Code will not tell which is faulty. To remove top: after removing three phillips head screws (leaving the L shaped part attached to the top) slide the top back about one and a half inches and lift it straight up.
Water leak
you would acess ut from under the main top. alittle involved but acessable,.. you need to remvoe teh four phillipsscres from with in the soap dispensor area. then remove the front door as well as th e2 screws oppisite t eh door hinge, then pop off the front cover. from there youll find 2 more 5/16 screws holding the top to the frame assy. then the main top can be flipped backward allowing you acess to the valve
Replacing hall sensor
The hall sensor is located in the back of the washer.  You need to get through the back panel to get to the hall sensor.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
