I also get bad7. Vo .11/01 code
SOURCE: Brew Unit Blocked
If when you first turn it on and it does not go through the self test and then says brew unit blocked. You may have a wire loose on the board, (common) The motor that drives the unit may be bad. In either case you should have a professional look at it. Google saeco repair and have choose an authorized saeco repar center.
SOURCE: brew group on saeco odea giro wont go back into machine
try to put in the dregbox to the machine, close the door and power on the machine. When the machine not make any noise, open the door and put in the brew group.
SOURCE: saeco italia has front red light explanation
This red light is to indicate if the water tank needs filling, if the bean hopper needs filling, or if the brew unit is not in the unit (after cleaning) or not in the correct position.
SOURCE: Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
