Pool & Spa Logo
T
Tracy Schofield Posted on Mar 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I know if the spa heater is on from my phone
Here2HelpYou
Level 3:
Master:
  • Master 592 Answers
  • Posted on Mar 17, 2019
Here2HelpYou
Master
Level 3:
Master:
Answers
592
Questions
0
Helped
152669
Points
4122
If it's capable( the spa) I'd assume you'll have to do Iliad the app rrom the google play store or Apple store, then synchronize your spa and phone over an Internet connection- that's usually how it works. See your owners manual to know which particular app you need!
How do I know if the spa heater is on from my phon - 2987c4cf-1f46-48c5-853b-3f6dcfbb9fb5-wh1s1tuztc1a5tdrmf0pblpw-4-0.jpeg
1helpful
Have a Pentair Easy Touch. Says spa water temp is 86 thermometer in spa says 96 have it programmed for 104 and indicator is on for heater but can't get it higher. Rheem heater is turned all the way up
could be the heater is defect, the thermostat is defect or the thermometer is defect. Try to rule out 2 of these and you know what is wrong. Or het heater just does not get any power?
Nov 01, 2014 • Pool & Spa
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Water temp 140+ degrees, Pump running, display shows Sn
What????
Portable Spa with its own components/equipment below (electric heater) or do you have a separate equipment set installed away from the spa. Or is this a swimming pool? With a gas heater?
Let us know more about what it is you have that has definitely malfunctioned!Make, Model, Serial numbers. And if it is a portable self contained spa, not just the spa maker, see if you can isolate the control system & its specific information.
Dec 29, 2012 • Pool & Spa
I have a mastertemp pentair heater. No error codes. Pool heater works fine-- spa heater button will not light or operate. Any sugestions?
Since I don't know exactly what model you have I can only suggest you call the Pentair technical support at 800-693-0971 andthey should be able to help you figure this issue out.
I hope this helps.
GFI plug is heating up on spa causing motor to not come on
unless plug is bad u will need to check the motor or heater one of them is pulling high amps heating up plug--oil motor may help--but will need to check the amperage on the motor and or if heater is cause if no amp probe --when system is cooled plug in and turn down heat setting let motor for a while if plug heats up or motor goes off on over heat know problem is with motor or plug-if no change now add heater if plug gets hot and turns off when heater is applied know heater is problem
I have a jandy LT pool heater and the spa light is blinking while it is heating the spa. should this be happening or am I doing something wrong?
It is just letting you know it is in the spa mode rather than the pool mode. Your OK, but it is good to ask when not sure. If more people did this I would probally go out of busness.
I have an acura spa system. I need to know how to
How to replace 2 filters in above ground spa
Apr 17, 2009 • Pool & Spa
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
