Televison & Video Logo
Chris Youngs Posted on Mar 17, 2019
How do I get my O and M16A sound bar to Bluetooth to my TCL roku TV
  • Chris Youngs Mar 17, 2019
    It's an ONN 16" SOUNDBAR NOT PAIRING TO MY TCL ROKU TV. HOW DO I RESET THE SOUNDBAR
flag1aa
Level 1:
  • Contributor 21 Answers
  • Posted on Apr 01, 2019
flag1aa
Contributor
Level 1:
Answers
21
Questions
Helped
7103
Points
37
5 Related Answers
txslim55
txslim55
  • 1104 Answers
  • Posted on Aug 23, 2015
SOURCE: I lost my remote control from my new smart TV TCL Roku TV 40 inch what do I do where can I get a new remote control fast
Remotes One For All Global
richie46
  • 12962 Answers
  • Posted on Aug 30, 2015
SOURCE: I did a factory reset of my tcl roku 42" tv and all tiles were removed. How do i get them back?
When you do a factory reset it eliminates everything and restores unit to the way it came out the box.
You need to go through the set up procedure from scratch with passwords, etc so unit will then download the tiles from your roku account. Check under the settings section to see if you have a listing there for resetting up. If not contact support at TCL and they will tell you what to do.
gopakumarg43
  • 76851 Answers
  • Posted on May 09, 2016
SOURCE: My 42 inch tcl roku smart tv is making a popping noise sometimes what does this mesn
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
richie46
  • 12962 Answers
  • Posted on Sep 01, 2017
SOURCE: I have a TCL roku smart tv I need to change it from channel 3 so I can use on air antenna tv any suggestions ty
Use remote button to change channels - check manual for directions.
miranda_ncoo
miranda cook
  • 39 Answers
  • Posted on Dec 02, 2017
SOURCE: My 7 year old tv tcl, is flashing menu,changing channels and turns off by itself. No roku or extra software
There's a button stuck either on the TV it's self or on the remote
How to sync TCL ROKU TV to LG sound bar
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
Why can't I pair my Samsung sound bar (HW-F355) and TCL Roku TV (55S421) to my Spectrum remote control (URC1160)?
Make sure that all remotes are using same technology. Most remotes use infrared but many modern remotes are bluetooth and they cannot be programmed in infrared remote.
What is the code for keyin rm 1107+4 for tcl remote..tried all but still not working
Program Your Cable or Satellite Remote Control to Work with Your TCL Roku TV
Providers Codes for TCL Roku TVs Programming Instructions Comcast Cable (Xfinity) 11756, 12434, 12290, 12292 Comcast Cox Communications 1756, 11756, 12434 Cox DISH Satellite TV 1756, 535, 645 DISH Network Frontier Communications 688 Frontier Communications https://support.tclusa.com/tv-remote-codes/roku-tv-remote-codes
2answers
I don't know where I control the volume on a TCL Roku TV Model 55R512 Remote. The TV is in mute mode and I can't unmute it.
On some TCL Roku TV remotes, pressing Volume Up un-mutes the TV. Pressing Volume Down enough times will mute the TV. (A few models have a physical Mute button on the side of the TV.) If the TV speakers have been disabled, you'll need to go through the Settings or Options menu instead. (If the unit was used with a sound system, that would be common.)
For more specific information, please add a comment with the TV model. Usually the remote instructions are in the TV documentation. I can't find any TCL TV documentation that lists the 55R512 remote.
I hope this helps.
2answers
How to activate Roku device
To enjoy the streaming capabilities of your TCL Roko TV, it should be connected to the Internet. This can be done via WiFi (available on all TCL Roku TVs) or Ethernet cable (applicable only for TCL Roku 4K TVs). Here's a quick video that you can connect your TCL Roku TV to your home wireless network. You can also mention the step-by-step instructions given below, choose your preferred connection. For more information visit our site: http://www.rokucomlink.info/
How do I get better sound with my roku tv
The speakers on a lot of TVs are not very good quality and seem to rely on owners providing their own audio solution. You have a couple of options if the TV speakers are not up to expectations.
1. Sound Bar - available from Audio/video retailers/Amazon.com etc.
2. If you have a hifi system or Ipod dock in your house with a 3.5mm jack input, and you TV has a 3.5mm jack headphone socket then you could connect it up and this will use the speakers on your audio equipment which will improve the output.
Top Roku Televison & Video Experts
vince
Paul Carew
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
