SOURCE: psp music sound problem
Could you please check the music bitrate you downloaded to your PSP? It should have at least 128 or 192 as its bitrate value to get a decent sound.
Also do not set your PSP volume too high as it may hurt your hearing (when using headphone) or it may hurt your PSP system speaker (when not using headphone).
I recommend you to always enable the AVLS (Automatic Volume Limitation System). You can always choose to activate/deactivate AVLS from the System Settings menu.
SOURCE: I have a seiko musical wall clock that no longer
mcdevito75 here, I'd bring the clock to a small watch repair shop in the area and have them look at it.
SOURCE: my seiko motion clock face opens and does not
Thank you for contacting FixYa I am not as experienced in the clock side of Seiko, but I did find their website and it is filled with great recommendations for clock repair. I would highly recommend you contact Seiko on this. Best regards. Here is a link to go to: http://www.seikoclocks.com/#FAQ Thanks for your rating too!! Jewel
SOURCE: My seiko musical wall clock
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
SOURCE: INSTRUCTIONS
try this link
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
