Kenmore Elite Heavy Duty King Size Quet Pak III 3 speed motor with 6 speed combinations.
May help
https://www.repairclinic.com/Video/Video-Landing/2900-8/Electric-Dryer-Drum-Won-t-Turn-Dryer-Troubleshooting
https://www.youtube.com/watch?v=QNa6zfzrm5k
https://www.google.com/search?hl=en&biw=1366&bih=651&ei=mN2NXJn6EsXj_AbnsYbIBA&q=replace+dryer+belt+Kenmore+Elite+Heavy+Duty+King+Size+Quet+Pak+III&oq=replace+dryer+belt+Kenmore+Elite+Heavy+Duty+King+Size+Quet+Pak+III&gs_l=psy-ab.12...31431.87601..90702...2.0..0.119.4018.31j13......0....1j2..gws-wiz.....6..0i71j35i39j0i22i30j0i131j0j0i67j0i20i263.lwpVdvVG5GE#kpvalbx=1
https://www.youtube.com/watch?v=nOEnSB7JhKU
https://www.youtube.com/watch?v=2bVoelV7M7Y
SOURCE: kenmore agitates doenst spin
There are 3 things that may be wrong.
The timer is keeping the transmission in neutral drain.
The clutch is slipping.
The basket drive block that supports the basket has failed.
Aimiel is correct that you will need to see what is happening during the spin to diagnose the problem. Please post the complete model number from the top under the lid and I will try to walk you through checking it.
Thanks/Mike
SOURCE: Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
SOURCE: My kenmore elite heavy duty king size model #
That is what I suspected. Thanks for the reply.
SOURCE: kenmore elite heavy duty king-size
I'm
sorry to say, this almost certainly means that the main bearings on the drum have failed. This
is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the
machine and removing the drum from the chassis, splitting it, removing pressed
in bearings and then sourcing and re-fitting new bearings. To
be frank, the cost of a bearing set (if they are replaceable , and most are)
will be about £20 (($30) or so. But its a long and horrible job if you haven't
done it before. I know professionals who claim they can do a bearing change in
under an hour, I've done a few and it takes me about 2 hours by the time I
