It is all clean and will give coffee from the small basket
SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
SOURCE: when I press the button with the large coffee cup
maybe you aren't putting enough coffe in to start with
SOURCE: It only makes one size coffee. When you hit the
my machine is the antony worrall thompson espresso coffee maker breville
SOURCE: My Keurig is only showing a blue light for the
1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker. 5. Power on machine. 6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage Not sure about why only one light comes on. Hope this helps some.
