Hp office jet 4635 cartridge hp61xl
SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
Figure 2: Removing the rear access door
Preventing paper jams
The following information will help prevent paper jams from occurring:
SOURCE: Won't accept non-HP cartridge
You ask "Is this a common problem with non-HP cartridges? " It is a possiblity.
Where did you purchase the cartridges from?
This error might be caused by defective printhead or sensors
Are you removing the 2 protective caps from the cartridges?
Read this HP page:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01451117&lc=en&dlc=en&cc=us&lang=en&rule=17507&product=3203059
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
SOURCE: hp 920 xl ink cartridge filling instructions anyone have them
to refill 920:
SOURCE: hp office jet j5780 cartridge error: cartridge on right must be replaced
Switch off, Remove catridge and Clean any leakage in the printer.
Clean the catridge with saliva if u do not have any cleaning liquide. Put the catridges back switch on and you are there. My hardware officer just tried it this morning and it worked like magic.
Note make sure all leakages are removed.
Hi Mickey McDowell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?what message are you getting?
