I have removed the back screws and two on the inside front of the top. The top won't come loose at the front. How do I get the front of the top loose?
SOURCE: maytag neptune
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
SOURCE: Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
SOURCE: I am trying to get
First, I'd like to know why you are trying to open it, just in case you don't need to. No audio for instance sometimes is an issue that can actually be solved without opening up the head of the unit.
Give me an idea what the issue is, and I'll tell you if you even need to open it up.
SOURCE: water dispenser wont shut-off
Check the solenoid valve is not stuck open. It lets water in, pushing cold water out, and if stuck will not shut off.. It may even have a broken spring, but that is quite unusual
