SOURCE: Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts:
About the Atomic Clock
The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
“ + , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
SOURCE: Sharp Atomic Clock spc 373 won't display correct time/zone
To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
SOURCE: Sharp SPC 373 transmittting temp 179 for a month
Unfortunately I have the same Sharp atomic clock with the same bad remote temp transmitter and having the same 179 result displayed. Can't find a replacement anywhere.
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
SOURCE: echo drive skyhawk,My watch's time zone is always one hour behind
You posted this in January, which is not during daylight savings time. The SMT setting doesn't turn on automatic DST switching for a particular timezone; rather, it is a manual override to adjust timezones to DST when it is actually active. There is no automatic DST adjustment for this watch (according to their FAQ). Turn SMT to OF for all timezones during winter months, and ON for applicable timezones during SuMmer Time (SMT).
