Jorge Lopez Posted on Mar 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why when put new batteries set time and zone after a while go back one hour
Lawrence Oravetz
Level 3:
  • Audio Player... Master 10,558 Answers
  • Posted on Mar 17, 2019
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2695707
Points
29284
You have to make sure daylight savings in set correctly
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Feb 28, 2009
SOURCE: Set correct time zone
you should be able to get instructions from bulova website.
Anonymous
  • Posted on Nov 01, 2009
SOURCE: setting time zone
found manual--
Remove from email listing and send no further communiques.
Anonymous
  • Posted on Jun 14, 2010
SOURCE: Put new battery in wave cepor now can't get it in
It may well be that the digital time displayed on the LCD is correct, but the hands (referred to as analog time in the manual) do not match.
If this is the case, to set the so called analog time:
Press the lower left button six times to enter HS (hand setting) mode.
Then press and hold the upper left button until the display starts to flash.
You can now use the two buttons on the right to move the hands forward or backwards to exactly the same ime as the digital LCD display.
When finished adjusting the hands press the upper left button one last time to exit.
Anonymous
  • Posted on Oct 28, 2010
SOURCE: I have a Westclox, Calander
It's most likely because of Daylight Saving Time. Your clock receives a signal through the air once a day from the actual atomic clock, much like a cell phone receives the time from your cell phone service provider, and it automatically resets itself to the exact time each time it receives this signal. Remember that the middle of the year (the second Sunday in March until the first Sunday in November in the US) is Daylight Saving Time for much of the United States. The clock has an option that allows you to set whether you are observing Daylight Saving Time or not. If this is set to "off", the time will be one hour behind until Daylight Saving Time ends (November 7th). Make sure this is set properly, and your problem will be solved.
Anonymous
  • 710 Answers
  • Posted on May 30, 2011
SOURCE: My wireless weather station projection
I would need your make and model of weather station in order to get you the information you need.
Thanks,
Handie Andie
Sharp Weather Station model SPC 775 when I put new batteries and set time and zone after a while the time goes back on hour ? ? ?
I guess that the Time Zone you entered is for B.S.T. and the programme automatically compensates for Daylight saving time (i.e. one hour back) during our winter. Try setting time to B.S.T. and it will jump back to D.S.T. which is correct until the end of the month if you are in the u.k.
2answers
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    How do I adjust the settings on a 625-236 atomic clock
    If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
    To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
    The manual is available here: http://www.theclockdepot.com/howard-miller-625-236-techtime-operations-manual.pdf .
    I hope this helps.
    Oct 06, 2014 • Home
    1helpful
    How do I set the time zone? It run out of battery so when I changed it, the time zone is pacific and I need to change it to mountain time.
    To change the time zone, open the control compartment cover on the bottom of the clock. Locate the "Time Zone" switch and set it to the appropriate time zone for your area. Six time zones are programmed into your clock, "A" for Atlantic, "E" for Eastern, "C" for Central, "M" for Mountain, "P" for Pacific and "H" for Hawaiian. Once you've chosen the correct time zone for your Brookstone digital desk clock, you must select whether you want the clock to operate using the 12-hour or 24-hour format. The clock is set to the 12-hour format by default. If you'd like to change the setting to the 24-hour format, locate the "Time Format" switch on the bottom of the clock and flip it to "24-hour".
    You can also decide whether to turn your clock's automatic Daylight Savings Time feature on or off. If you turn the feature on, your clock will automatically move forward by one hour at 2:00 a.m. on the first Sunday in March and fall back by one hour at 2:00 a.m. on the first Sunday in November. To choose your preference, locate the "DST" switch on the bottom of the clock and flip it to "Autoicon1.png" or "Off".
    Read more: http://www.ehow.com/way_5585650_brookstone-digital-desk-clock-instructions.html#ixzz2phA7kQ1b
    My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
    Hi lufberg,
    I see you need help with your radio controlled clock.
    Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
    Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
    I hope this will help.
    Thank you for choosing Fixya,
    mvincentc
    Jul 04, 2011 • Vacuums
    3helpful
    Magellan roadmate 2036 how to set my local time
    1. From the
    Main Menu screen, tap the Settings icon .
    2. Tap
    System.
    Setting Languages
    1. Access the
    System Settings menu (above).
    2. Tap
    Languages.
    3. Tap on the desired language.
    4. Tap the back arrow .
    5. The Magellan RoadMate receiver will reboot if you change the language.
    Setting Auto Power
    Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
    automatically.
    1. Access the
    2. Tap
    Auto Power.
    3. Tap on the desired duration.
    Setting Brightness
    1. Access the
    2. Tap
    Brightness.
    3. Tap in the brightness slider to set the brightness of the display.
    The
    Dim on Battery Power option will prolong battery life by dimming the display while using internal battery
    power. Check to turn this option on.
    Setting the Time Format
    1. Access the
    2. Tap
    Time Format.
    3. Tap on 24 Hours or 12 hours with am/pm.
    Selecting the Time Zone (daylight savings on/off)
    1. Access the
    2. Tap
    Time Zone.
    3. Check Auto Time Zone or select your time zone from one of the cities in the list.
    1helpful
    Clock is 2 hours ahead of actual cst time
    If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
    Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
    I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
    May 06, 2011 • Watches
    2helpful
    2answers
    Since DST started I cannot get my radio controlled clock to reset to the actual time. I replaced the battery and now the clock will set itself four hours from the time it stopped, then stop again. i have...
    take the batteries back out and leave them out for at least 2 minutes. next put the batteries back in and put the clock near a wall or window so that the back of the clock faces colorado (where the WMV transmitter is),. It will most likely take all night for it to set properly, just after you put in the battery make sure that you have set your time zone on the back of the clock and if there is DST button press that too. just be patient, it will set itself. worse comes to worse you can set it by hand, but kind of defeats the purpose of having an "atomic clock". by the way the reason they call it "atomic" is becausee WMV's clock is tracking the decay of the Seisum atom, or some such bs.
    The clock keeps setting itself back an hour
    first thing to check is if this happens on the BIOS as well. Restart the computer and press the specific key displayed on the screen to enter BIOS. From there, observe if the time is also not correct. if it also goes back an hour, this would be an issue with the CMOS battery. try to remove and reconnect the CMOS battery, restore BIOS to defaults and set the correct time again. If this does not work, may be time to get a new CMOS battery. On the other hand, if it happens only on the time in Windows, right-click the system clock on the taskbar, then make sure your time zone and date and tim are corect. If your time zone uses DST, set it appropriately. Then click the Internet Time tab and uncheck the option to synchronize to an Internet Time Server, then click OK. It may help to restart the system in this case.
    2helpful
    2answers
    My solar clock needs setting. I set it back an
    1) Pull the batteries and replace them, or gently insert a straightened paper clip into the "reset" hole in the back of the clock. The clock will beep.
    2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
    3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
    4) Press and HOLD the "set" button down untill the hours digits start to flash2.gif.
    5) Now press the "set" button again six times. The time zone characters will flash.
    6) Press the "adjust" button untill your time zone appears.
    7) Press the "mode" button to return the clock to normal operation.
    8) Press the "adjust" button to display the day-of-week.
     Grubhead
    Grubhead
    SmartAviator
    SmartAviator
