Perhaps the main circuit board or motherboard? It wouldn't hurt to check it out and look closely at all of the little "pathways" between the various components, it's highly probable that the intense vibration and movement caused a solder joint to come loose or a component may not be connected as it should be. Break out your voltmeter and use the continuity tester to your advantage to verify circuits are completed as they should be. I'd imagine you'll find an issue, if not my apologies but that's been the case in my experience more than once. Best of Luck Friend!
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
SOURCE: Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
SOURCE: My Whirlpool ghw9100lw1 isn't rinsing...
"F02" is a Long Drain error code. This generally means you have a clog or restriction in the drainage system somewhere. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In the majority of the cases, all you have to do is clean out the drain pump reservoir. The instructions are included in the link I provided. If the problem does not go away after you have performed all these preliminary measures, the pump may be damaged and require replacement.
This error code gets generated if the drain cycle exceeds 8 minutes. If the pump impeller/motor gets damaged, the pump may not pump at the proper volume and the error code will continue to reappear.
A replacement (if required) can be purchased at any of the following websites:
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The pump is sold as a complete unit. You cannot buy just the motor.
If you have questions about this repair, or require addtional assistance, please let me know. I hope you find this information helpful.
