SOURCE: Laptop shuts off when unplugged, battery is fully charged
Chosenone, Even though the battery meter shows it fully charged I doubt it?s correct. Over time rechargeable batteries loose their ability to store power. How long depends on the battery manufacturer and how well you treat it but you can consider yourself fortunate if your battery lasts three or four years. Beware of people who suggest you take apart your batter to bypass the safeties or replace old battery cells. Defective or improperly handled batteries can overheat and cause fires when you least expect them. Let us know if you have any more questions and please don?t forget to rate this post.
SOURCE: Coleman 1500 power inverter has no output
I believe that the actual unit may have other problems and that you will need a schematic to aid in your troubleshooting of this issue. Once you have the schematic and a multiment you can check the voltages to see if things ar as they should be and then we can look at what is happening.
SOURCE: FUJI F20 Won't Power Up - Good and Charged Battery
Fuji FinePitteryx refuses to power up,even after new lith. batteries were installed
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
SOURCE: coleman powermate 1850 charge time
i advice you not to keep it plugged in too long...just about enough to get it workin....
:had a bad over-charge axcident..
