Repair, Calibrate or Request Field Service
Mitutoyo
https://www.mitutoyo.com > Contact Us
Whether you need immediate repair service or A2LA Accredited, NIST-traceable calibration of your measuring instruments, our highly skilled technicians ...
SOURCE: Missing Thimble screw
You can most likely get one at a clock repair shop if Mitutoyo won't help you out.
SOURCE: how to reset Mitutoyo 314-351
In order to reset the zero point for your specific micrometer, you will need to have a standard set of pre-set dimensional pin(s). You can check the attached link (page 71 of the Mitotoyo catalog) for the information you need). I guess you could try to find or make a pin with the same dimensions as those noted on the catalog page, but if you're using this in a manufacturing setting, you might have no choice but to purchase a set of gauges for calibrating your micrometer.
The only other option is to contact the manufacturer for an alternative method, but I doubt they'll be able to provide any alternative, as precision setting of the zero point is required for accurate readings with this specialty micrometer.
http://www.mitutoyo.co.jp/eng/products/micrometer/Micrometer_2.pdf
SOURCE: I need to adjust a 293-761-30 mitutoyo micrometer.
there should be a small silver spanner with a couple of pins protruding to do that with comes in the box if you haven`t got it come back to me
SOURCE: i need a replacement thimble lock for a mitutoyo
i image the 6 - 12" is a fairly expensive set. you could buy the 0-1" which has the same thimble lock. i have one at home. and switch them out. can be bought $100 or less brand new. or search for an ebay bargain.ive never heard of the thimble lock go missing or break before. its doubtful mititoyo supplies replacement parts for mics.
SOURCE: Hello, I need a manual
I dont know it there is a manual per se. Try this link to call MTI support....
http://www.mitutoyo.com/template2.aspx?id=20
Hello. Mitutoyo has both calibration and repair services if required.
Repair:
http://www.mitutoyo.com/template2.aspx?id=22
Calibration:
http://www.mitutoyo.com/template2.aspx?id=21
Hope this helps out. Thanks.
II just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site: http://Theprocoin.com
