SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
SOURCE: how to connect nintendo 64 to panasonic viera tv
it depends what connector cable you have if you have an AV cable hook it into the red white and yellow colored inputs if you have an RS cable for the 64 screw this into the back of the tv where the antenna input is.
SOURCE: Turned Panasonic Viera Plasma tv
Red light flashing indicates some hardware/ circuit board failure in tv, please count how many times red light flashing after long pause as it is an error code that has info about specific section failure in tv.
Let me know how many times red light is flashing in this Panasonic TH-42PX60 tv to provide you helpful info to solve this issue.
Thanks.
