It is a kenmore 665.13593k600. The way I can get it to work is if I shove it closed firmly, then I can get it to start after a few tries. Would a new panel control board help, or something else?
SOURCE: Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
SOURCE: Front panel on Kenmore Diswasher
Hi jenniferr922,
I'm Harvey the Master plumber.
Your question is: You purchased a white Kenmore dishwasher and you are redoing your kitchen and all of your appliances are Kenmore stainless steel. You were wondering if the front panel was the only replacement or if you needed to order something else for the control panel.
It's your choise. If you like the control panel, keep it. If not, replace it when you replace the white panel.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
SOURCE: Kenmore Elite Dishwasher- The touchpad
jodahabo,
can you post the rest sequence? i would love to try this!
thanks,
the_strum_one
