Go into audio and activate optical
SOURCE: ilo 42"widescreen lcd tv
I hooked a sylvania 220sl8 dvd/cd/vcr, The vcr works, the dvd does not. Why?
SOURCE: hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
SOURCE: hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one:
http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
SOURCE: We're trying to hook up an ilive sound bar to a samsung 42
If you tried hooking each unit up one at a time without the box and they work either a setting on that box is wrong or there is a problem with the box.
